It is currently Sat Aug 02, 2025 3:24 am
 Post subject: Walnut for Back Braces?
PostPosted: Sat May 25, 2019 11:27 am
Last Name: Sollod
How would walnut work for back bracing? I've got some I could use...
www.swiftcreekguitars.com
PostPosted: Sat May 25, 2019 12:16 pm
If you check the wood database you will find walnut to be close in specs to the properties of mahogany, which is about what I would expect. I have no problem substituting walnut for mahogany for most uses (avoid using it around animals). So if you would use mahogany for back braces, which some do, why not walnut?
PostPosted: Sat May 25, 2019 12:52 pm
Don't see why not...
PostPosted: Sat May 25, 2019 4:36 pm
Yup; works great. So does cherry.
PostPosted: Sat May 25, 2019 4:49 pm
Last Name: Beaver
City: Lake Forest
Clay, why the caution? Dangerous for pets?
Joe Beaver
Maker of Sawdust
PostPosted: Sat May 25, 2019 10:24 pm
Hi Joe,
Walnut wood is poisonous to horses and to some other animals if they ingest it. It is also poisonous to plants, so you don't want to mulch your garden with walnut shavings or saw dust.
